Agile PLM opmn can not started
本文标签: Agile PLM opmn can not started
opmnctl startall
opmnctl : starting opmn and all managed processes...
Failed to Start Service with error The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
(GetLastError()=1058)
Timed out waiting for OPMN to initialize. OPMN may be down or taking a long time to initialize. Will not attempt to start processes because OPMN is unreachable. If OPMN is initializing, retryin the command may prove successful. If OPMN is down, correct the underlying problem before retrying the command.
Cause:The Oracle-oc4jadminProcessManager service has been Disalbed.
Solution: Set the services as manual and Restart the OPMN.
发表于: 2011-12-13 22:49 阅读(982) 评论(0) 收藏 好文推荐
您尚未登录,请先【登录或注册
