Oracle Agile Engineering Collaboration INI File Attribute Definition
本文标签: Oracle Agile Engineering Collaboration INI File Attribute Definition
Each CAD connector has an INI configuation file that is used partially for defining attribute mapping:
每中CAD 连接器都有一个INI配置文件用来定义相应的属性映射:
SolidWorks , Solid Edge - 3DCADMapping.ini
Pro/ENGINEER - AcpCustomer9.ini
CATIA - AccCustomer9.ini
Unigraphics NX  - Ecu.ini
These files include sections for defining the following types of mappings:
这些文件包含了以下定义的类型:
     Mapping from CAD to PLM    从CAD 到PLM映射
   Attributes to be set for Designs or Documents in PLM , during the Save process
     在保存的过程中,将属性映射到PLM的设计或者文档对象中
  This is set separately for initial Saves and update Saves
     这个设置被分为 初始保存和更新保存
   Attributes to be set for Parts in PLM , during the Create Item/BOM process
     在创建项目/明细表的过程中,将属性设置到PLM的零件对象中。
 Mapping from PLM to CAD   从PLM映射到CAD
       Attributes to be updated from PLM Designs , Documents or Parts to CAD file properties
       把PLM中的设计、文档或者零件对象的属性更新到CAD 文件的属性中
    Based on using the Update Properties   command , or during the Save or Load commands (not supported in all CAD systems)
              通过使用更新属性命令,或者通过使用保存或者加载命令(不是所有的CAD 系统都支持)
              Attributes to be updated from PLM Designs , Documents or Parts to CAD drawing title blocks.
              将PLM系统中的设计、文档或者零件对象中的属性更新到CAD工程图的标题框中。
发表于: 2011-07-15 22:39 阅读(1793) 评论(1) 收藏 好文推荐
# re: Oracle Agile Engineering Collaboration INI File Attribute Definition
2011-07-19 10:52 | 传奇 | 1楼
图片显示不出来哦,您可以重新编辑一下~`
您尚未登录,请先【登录或注册
