Agile PLM Product Collaboration User Guide
本文标签: Agile PLM Product Collaboration
Product Collaboration Use Cases
产品协同使用案例
This section provides links or information about where to find details about performing the following Product Collaboration tasks:
本节提供的链接或信息是有关如何查找有关执行下列产品协作任务的详细信息:
    Search for Items
    Agile PLM provides a Quick Search , a Custom Search that a list of items attributes the Agile administrator configures and an Advanced Search , which allows you to define complex searches , including Where-used searches.
     In the Web Client navigation pane toolbar, click the Help button ?
    Create Item   创建项目
     Creating Items in Web Client   on page 16
     Creating Items in Java Client on page 18
     Creating an Item Using Add on page 19
     Creating an Item Using Save As on page 17
 Add Item to Preliminary BOM
      Web Client , Adding Items to the BOM Table of a Preliminary Item   85
      Java Client                         92
      Modifying the BOM Table of a Preliminary Item         97
 Viewing expanded view of a BOM    查看展开的BOM
      Expanding and Collapsing an Assembly        展开和收起一个装配体      80
      Expanding BOM Display Window ,Web Client    展开BOM 显示窗体  web客户端   83
      Using BOM Go To     81
  Create a Change against an item     创建一个更改
      Expanding and Collapsing an Assembly          80
      Expanding BOM Display window ,web Client     83
      Creating Changes       132
    Route a Change Order      指定一个更改单流程
       See Getting Started with Agile PLM ,chapter "Routing Objects with Workflows"
    Release a Change Order   发布一个更改单
        Releasing an Agile Item to Production   22
        See Getting Started with Agile PLM,chapter "Routing Objects with Workflows"
     Add Affected Items to Changes    增加一个影响项目到更改
        Adding an Item to the Affected Items Tab     145
        Web Client Adding Items to the Affected Items Table    146
        Java Client ,Using the Add Affected Items Wizard   149
     Add Manufacturer Parts to Preliminary Items
        Adding a Manufacturer Part to the Manufacturers Tab    64
    Redline BOMs and AML
        Redlining the BOM of a Released Item    108
        Redlining Manufacturers Tab          67
     Redine item attributes
        Title Block Redline Tab of ECOs and MCOs    157
        What are Change-Controlled Attributes?           225
     Checkout /Checkin Attributes against Items/Changes /Manufacturer Parts / Manufacturers
         see Getting Starting with Agile PLM chapter "working with Attachments"
发表于: 2011-01-16 00:11 joyopod 阅读(2235) 评论(0) 收藏 好文推荐
您尚未登录,请先【登录或注册
