Set the following parameters on the machine
| Press the [Parameters] button for parameters settings |
| Press the [PAGE DOWN] button and select the 'Settings 2' submode |
| Set the 'MODE SELECT' switch to 'MDI' |
| Set the 'NO PWE' parameter to 1 and press the 'Input' button. After changing parameters below, change this value to 0 again |
| Select the 'Settings 2' submode |
| Set I/O = 1 |
With help of 'PAGE DOWN' and 'PAGE UP' buttons change bits in the following parameters. Please, don't change bits that didn't print in the table below
#002 (stop bit and data format)
| bit 0 |
0 (1 stop bit) |
| bit 2 |
0 (RS232) |
| bit 3 |
1 (ASCII) | |
#0552 (baud rate). Set this parameter = 9
| Baud |
Parameter value |
| 2400 |
9 |
| 4800 |
10 |
| 9600 |
11 |
| 19200 |
12 | |
#0038 (IO device)
| bit 1 |
0 |
| bit 2 |
1 |
| bit 4 |
0 |
| bit 5 |
1 |
| bit 6 |
0 |
| bit 7 |
1 | |
| #0051 (Parity)
#0055 (Additional parameters)
| bit 0 |
1 (ASCII) |
| bit 1 |
0 (CR) |
| bit 2 |
0 (Protocol A) |
| bit 3 |
0 (RS232) | | | |
Set the following parameters on the PC
Serial port tab
| Machine name |
Fanuc 0M-D |
| Serial port |
COM2 (or any free COM port) |
| Baud |
2400 |
| Data bits |
7 |
| Parity |
Even |
| Stop bits |
流控设置:XON/XOFF |
更多机床参数设置请浏览 WWW.MESBBS.COM
发表于:
2008-07-25 13:44 Steven 阅读(2370)
评论(4) 收藏(0)
好文推荐
